JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Servo set up on H9 cap & 10X
Reply
Old 04-21-2004, 02:49 PM
J roc
J roc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Servo set up on H9 cap & 10X
Danny.. I am planning to use 4 channels for the ailerons, One for each aileron servo. ail, aux 1, aux 2, and aux 4. This way I figure I can tweak each center and travel independantly. Using the aileron as master.It seems to work on the bench. Do you forsee any problems with this setup? PCM 1ox one awesome radio. On the next version there should be a program for doing this. Would make setting up easier, especially bipes. Thanks.
J roc is offline
Old 04-22-2004, 09:45 AM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Servo set up on H9 cap & 10X
No, I don't forsee any problems with that. Generally what I do to program 4 servo wings (2 on each side) is to use the flaperon function, then use 2 multi-point mixes (aileron to an aux channel) so that I can adjust the servos travel throughout the range of motion to better match the servos together. Also it is a very good idea to use a current meter to set up the servos so they do not fight each other, you can either use a meter from radio shack or similar, or we have one available from Hangar 9, part number HAN172.
dsnyder is offline
