JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Using a 421 as a buddy box off of a 622
Reply
Old 04-27-2004, 09:13 PM
Barnz316
My Feedback: (26)
Barnz316's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Using a 421 as a buddy box off of a 622
Hey Danny,
First off, thank you for all of the advice that you give all of us. Its greatly appreciated. Now to the point, Im using a XF421EX as a buddy box off of a XF622 master. The servos are wired according to the 622 manual and works correctly but when I connect the 421 as a buddy box and hit the gear switch to activate the flaperons, only the right flap cycles. The 421's manual says to hook the second aileron servo up to the gear channel and the 622 says to hook it to the AUX1 channel. Which is right? If I wire it to the 622, how do I get the flaperons to work properly? Im sure there is a cure for this but I cant for the life of me figure it out. If it matters, Im using a R700 RX. Thank you in advance.
Barnz316 is offline
Old 04-28-2004, 08:45 AM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Using a 421 as a buddy box off of a 622
I don't think there is a good solution here. As the 421 is a 5 channel system, it will not control 6 channels, and the 622 uses channel 6 as the second aileron channel. The 421 in flaperon uses channel 5. The only way that you could use this set up in a buddy box is to Y harness or matchbox the 2 ailerons together. The slave system must be capable and set up completely for the model in a buddy box set up (except for the 6102 and the 10X air which have the pilot link function).
dsnyder is offline
