JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
jr xp662 spoilerons on a switch? how?
Reply
Old 04-30-2004, 03:29 PM
rv4pilott
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default jr xp662 spoilerons on a switch? how?
Hello! I have a JR xp662 that I would like to set up with spoilerons slaved to a switch to turn the function on and off. Can this be done on this radio? I see the flaperon funtion that I can use a negative value to operate as spoilerons, but I do'nt see where to assign it to a switch. Obviously I have two aileron servos plugged into two different channels. Thanx for your help! Jeff
rv4pilott is offline
Old 04-30-2004, 04:32 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: jr xp662 spoilerons on a switch? how?
The function is automatically active on the flap switch when you activate flaperon. What you can do is put the flap switch in the position that the ailerons move as flaps, and zero the travel adjust value in that switch position. Then leave the travel adjust value in the other switch position. If you want to reverse the direction of the switch, swap channels that the servos are plugged into the receiver and reset the travel adjust above accordingly.
dsnyder is offline
