JR 6102 Dual Elevator Servos
My Feedback: (45)
I am going to use two elevator servos. One on the elevator channel, the other on the gear channel. I was wondering if there was something I should know before trying this per the instruction manual. Thanks for your help in advance.
RE: JR 6102 Dual Elevator Servos
Just use mix number 4, set the mix up as an elevator to gear mix, and set the rates at 100%. Also inhibit the gear switch in the switch select function.
