JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Bad JR 537 servo??
Reply
Old 05-22-2004, 06:26 PM
skorman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bad JR 537 servo??
I took my Magic Extra out to the field today. After setting it up, I noticed that there was a noticeable amount of up elevator with the sticks at neutral. I checked the linkages and the servo and all seemed solid. I even checked that all servos were seated properly in the receiver. So I adjusted the elevator sub trim to put the elevator where it should be. The first flight was great. The second flight however was not. After a couple of minutes, the elevator trim went haywire and gave me so much down elevator that my plane did an outside loop all by itself. I chopped the throttle, gave it all the up trim I could and while holding up elevator brought it in for a landing. The plane got down in one piece thankfully, but does the problem sound like a bad servo? It is a JR 537 and my radio and receiver is JR.
skorman is offline
Old 05-24-2004, 09:52 AM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bad JR 537 servo??
It does sound possible that it could be a servo problem, or a problem with an extension or connector. It may be best to send in that servo for a check up or install a new servo, and check all connections and replace any suspected extensions etc.
dsnyder is offline
Old 05-29-2004, 09:39 AM
skorman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just replaced the 537 with a JR Z590M high torque servo with metal gears. (Suggested by my lhs).
skorman is offline
