JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
JR X-378 question
Reply
Old 05-25-2004, 12:11 AM
tocano
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JR X-378 question
I have a JR X-378 radio mode 1 and I would like to know if I can program it so I can disable the aileron servo and make rudder function controlled by aileron stick with a flick of a switch. Basically I have an eletric plane with aileron function and I like to teach my son to fly and I like to make it easy for him by switching the plane from 4 channels to 3 channels plane once I get it high enough in the air. And to have the aileron stick on the left stick and rudder on the right stick (with throttle) instead of on one stick.
Can I do this with my radio?
tocano is offline
Old 05-25-2004, 10:07 AM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: JR X-378 question
Yes, you could do that with 2 program mixes. For the first mix, set up an aileron to aileron mix, assign the mix to the switch of your choice, then set the rates at -100% for both directions of aileron (move the aileron stick to switch between the 2 rates of the mix). Then set up an aileron to rudder mix, assign the mix to the same switch as the above mix, and set the rates at +100% in both directions of aileron. Please let us know if you have any further questions.
dsnyder is offline
