JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
10X smoke setup
Reply
Old 05-25-2004, 01:42 PM
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 10X smoke setup
I have a Don Harris pump, and want to know the best way to set up my 10X for an "on/off" switch or slave to throttle with a switch? Please give details.
AEROSHELDON is offline
Old 05-25-2004, 02:37 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 10X smoke setup
You could do it either way, either setting it up on a switch, or on a switch with the throttle. That is your choice. To set it up on a switch, set up a mix where you mix the channel that you plug the smoke pump into, to itself, assign the mix to the switch of your choice, and set the rates as needed to get the pump to turn on/off as desired. Or you can set up a throttle to the channel that the pump is plugged into mix, assign the mix to the switch of your choice, and set the rates as needed with the switch in the on position. I would need more details of your set up to assist with the programming further, such as what channel you are going to use for the pump, how you want the pump set up (off of the throttle or not), but I won't be able to give exact values to use for your particular set up. Also feel free to give a call to one of our techs at 877-504-0233 for further assistance.
dsnyder is offline
Old 05-28-2004, 12:33 AM
JohnVH
My Feedback: (38)
JohnVH's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
in my 40% I put it on the gear switch, easy to reach, and dont use retracts on a giant aerobat anyway
JohnVH is offline
