JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
PCM 10SX question--please help
Reply
Old 05-27-2004, 11:12 AM
AJF--2
My Feedback: (119)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default PCM 10SX question--please help
I know this is an older radio but it seems as though I should be able to program 2 elevator servos. Can you help-- or do I just need to buy a Y connector with a reverser? Thanks in advance.
AJF--2 is offline
Old 05-27-2004, 11:35 AM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: PCM 10SX question--please help
Yes, you can do this with the 10SX system. I just set this up using channel 8 (aux 3) as the second elevator channel. Go to code 51 program mix 1, or any open program mix, press 3, then 8, then enter. Now press page, and press SEL under MASTER until it says INCL, then press SEL under TRIM until it says ON. Now press page again and enter in +100% percentages holding both up and down elevator. Now go to code 17 Trimmer func, and press the key under AUX 3 until it says INH. Then use travel adjust, sub trim, etc to set up both channels.
dsnyder is offline
Old 05-27-2004, 09:43 PM
AJF--2
My Feedback: (119)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks a ton!!
AJF--2 is offline
