JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
8417
Reply
Old 05-30-2004, 11:18 PM
buzzsaw46
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 8417
Hi Danny,
I have a couple older 8417's and I'm not sure if I got them before the motor replacement or not is there any way I could check to see if mine have the newer motor?
Thank you
Jason
buzzsaw46 is offline
Old 06-01-2004, 09:24 AM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 8417
If the servo has a dot on the servo case (a stick on dot, I believe they are generally a blue dot) it is the newer motor. If it doesn't have a dot, it likely is an older motor (unless the dot was removed from the servo). To find out you would need to send the servo in.
dsnyder is offline
