6102 Elevator-Flap(eron) mix
ON, CANADA
Hi Danny,
I'm setting up a Smith Super Special (Funfly type aircraft). I have flaperons setup, now I've set up elevator flap mixing, ok so far.
Next I set up exponential on the elevator but apparently this has no effect on the E->F mix?...
Q: How do I set up expo on the elevator and ensure equivalent throws to the Flap mix?
RE: 6102 Elevator-Flap(eron) mix
I'm not sure I understand the question. If you set the expo, the flaps simply follow the elevator. So if you increase the expo, the flaps will move correspondingly. This can be witnessed by setting one dual rate with a large amount of expo and another rate with no expo, go to the servo monitor, and watch the results of moving the elevator stick, and switching the dual rate switch.
