JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
JR 8103 Turn Off Knobs
Reply
Old 06-02-2004, 01:27 PM
Buzykid
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JR 8103 Turn Off Knobs
I am using an 8103 with dual elevators and ailerons. They are mixed in on elev to spoi, and ail to flap. Is there any way to turn off the knobs so that I do not mess with the trim settings. Or do you suggest another setup as to avoid this problem.
Ryan
Buzykid is offline
Old 06-02-2004, 01:31 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: JR 8103 Turn Off Knobs
For the flap pot, you can go to the flap pot function and inhibit it. For other channels the best way to eliminate the function of the pot or switch is to set up a program mix, mixing the channel of the pot or switch to itself, and set both of the rates at -100%. For your second aileron channel, you can simply activate flaperon in the wing type function rather than using a program mix.
dsnyder is offline
