8103 Programming Timer Question
TX
Hello, I have the heli version of the 8103. While flying planes, I would like to use the timer and the snap roll function. Is there a switch to move the timer to so I can use the momentary switch for the snap roll function? Thanks, Bill
CA
RE: 8103 Programming Timer Question
Hey Bill, I was in the same boat last year. I found that you can start the timer by pressing either of the chan buttons. Be careful that you don't press the +-, LR buttons as that will change/set the snap roll direction. Have fun.
That is correct, the channel right or left keys are used to start/stop the timer when the snap roll or trainer functions are active. The clear key resets the timer.
