Screw size for DS8611?
Danny,
What is the screw size used to secure the servo arm on the DS8611 servo? I like to replace the phillips screw with a hex screw - you can actually get it out when you need to - when you use loctite. This is one smooth fast servo. Will definately get more as the need arises. Thanks.
Dan W
Dan W
