8103 dual rate end point adj?
CA
Hi Danny,
Is there any way to adjust the dual rate end points in the 8103?
Example: If I set up the elev end points at 120% down and 140% up with d/r position 1 at 100%, then when I go to d/r position 0 at lets say 70%, can I adjust the end points again?
Or can I somehow adjust the d/r position 0 to get 70% down and 50% up?
Is the 8103 capable of adjusting the dual rates on each side of the stick?
Thanks for any help. (Hope answer is more than to get a 10X[X(]
RE: 8103 dual rate end point adj?
It is possible to adjust the dual rates, either increase or decrease, as desired for each "rate". You can also increase or decrease the overal travel through the travel adjust function, but this will affect the dual rates. It is however not possible to adjust the dual rate different for say up elevator different than down elevator. This can be done through the travel adjust function, but affects all the dual rates. The 10X does have this ability to adjust the dual rates in each direction, but the 8103 does not.
