DS 281 Servo Control Horn
Danny,
I received today a JR 6102 with 4 DS-281s. I noticed that the control horns are full size and the holes for the pushrods are rather large. I plan on using this system in a GWS aircraft and planned on using the micro EZ connectors. I was going to replace the current servos that I have installed with the DS281s. Are there control horns available with smaller holes? I read in FLY RC about the ETOC and that the JR team used DS281s. What kind of pushrods did they use and connection method? Thanks
RE: DS 281 Servo Control Horn
I don't know of a servo arm with a smaller hole at this time. What I usually do is drill a small hole in the location I choose, fill the hole with epoxy or similar adhesive and re-drill, or use the Dubro Micro EZ Links without any mods.
