transmitter questions
Dan I have 2 JR Transmitters that I have a question about.
One is a 622 and the other is a 347.
Am I correct in assuming that there is only one battery in the 622 TX?
In the 347 how often does the memory battery last? I have one that is 14 yrs old and I do not believe it has been replaceddd--is that possible? Does the 347 memory battery have to be replaced at Horizon?
As usual thanks for the help.
Paul Ryan
Paul Ryan
RE: transmitter questions
The 622 has a Lithium as well !
Re your 347, now is the time to send it in for a Lithium change. Yes it is possible for the Lithium to last that long, I did a set that was at least 12 years old. BUT I wouldnt delay any longer.
The main advantage of getting it changed by the authorised distributor is that they will hav ethe correct part, they know how to change it without causing damage and they will take the opportunity to give the set a check over at the same time. Oh... and they will calibrate the sticks and the A2D converter at the same time.
[8D]
[8D]
