X-347 Aileron trim in mixing
AL
Danny, I am setting up an 33% Aeroworks Extra 330 It has 2 servos in each wing which I have y'ed together. I have one Y plugged into the Aileron channel and have tried everything I can think of with the other wing Y to set it up so that I can mix them together and have the aileron TRIM adjust both side but nothing seems to work, it still only moves the aileron channel.
Am I missing something or can it not be done?
Andrew Smith
www.rocketcityrc.com
Andrew Smith
RE: X-347 Aileron trim in mixing
Go to the Wing selection function in the system mode (press and hold the up and down keys together and turn the radio on) and activate flaperon. Then you can go to the flap.p funtion in the function mode (press the up and down keys together twice from the system mode, or press them together once after turning the system on) and inhibit the pot by pressing clear until it says INH.
