E306/E151 Micro Servo
I am finishing of my Funtana 40 and was wondering if I could use the mentioned servo for the throttle. The reason I would like to use it is the weight and speed of the servos. And I have one.
Would you require more talk than the mentioned 0.5 kg that the ES306 provides?
RE: E306/E151 Micro Servo
I'm afraid I'm not familiar with those servos, however generally I would not recommend a micro servo due to the vibration levels in larger aircraft. Micro servos are designed for micro aircraft with low vibration levels, and many times are not adequate for larger aircraft.
