On board Lithium
On board Lithium
I need to replace an onboard Lithium battery on a 347 TX. What is the spec of the battery, and is there anything else I need to be aware of when replacing it?
Many thanks, Mike
Many thanks, Mike
RE: On board Lithium
The battery is a 3 volt lithium battery. It is a soldered in battery, it requires complete dissasembly of the system, it is difficult to get to, and requires excellent soldering skills. Also it is likely to require knoweledge of the system set up to reset the system when the system is re-assembled. I would recommend sending the system in for this battery change.
