xp8103 radio on but receiver not responding
Two weeks ago I used the radio and everything was working correctly. Today I turned on the radio and saw an error message. I turned off the radio and turned it back on and it was now showing the normal screen but the receiver and servos were not responding to transmitter inputs.
Do you have any idea as to what the problem may be.
Larry
Larry
RE: xp8103 radio on but receiver not responding
Do you know what the error message said on the screen? If in heli mode it may have said Warning F.Mode which means the flight mode switch is not in normal mode. It may have also said Batt which may indicate that the lithium battery was drained. In that case the memory is likely gone, which may have changed the modulation type, so it may not match the receiver and would not work. If the lithium is drained it will need to come in for service.
Thanks for the reply Danny. I think it probably did say Battery. I will send it into the shop tomorrow.
