Futaba Tx to JR Rx
Futaba Tx to JR Rx
Hi,
Been doing a setup of a new plane with a Futaba FF7 (set to ppm) and a JR700 Rx,
But I've been getting lots of jitter - I have found a note suggesting that a futaba Tx to JR Rx is a bad idea,
I this correct, and have you a quick techie reason.
Cheers
Dominic
Some of the most important things in life are invisible -
ie - Air, Lift ... Radio interference ...
Cheers
Dominic
RE: Futaba Tx to JR Rx
In the US they will not work together because they are on opposite signal shifts, other bands overseas may be different. It may be possible that there is a compatibility issue there, I do not recommend mixing radio equipment brands.
