xp6102 PCM
CA
xp6102 PCM
I have a Hanger 9 ( P51 1.50) I have used a reverser 'Y' to get the flaps to work together. Now the elevators work as ailerons because of the mounting positions of the servos, and because of the positions of the wire guides one of the servos can not be reversed to cure the problem. Do I have to use a reverser 'Y' on this also? or can the radio be reprogrammed. Also what is AUX2 used for.
RE: xp6102 PCM
If you are using dual ailerons, you will need a reversing Y harness for the elevator as well. If you have the ailerons in a Y harness, you could mix together the elevators using channel 6 as the second channel. In a 6 channel system such as the 6102 the aux 2 port in the receiver will not be used.
