8103 throttle up-down
My Feedback: (10)
GA
Hi Danny:
I have two 8103's and to due to DB noise limits at our field I need to flip a switch and retard full throttle 10 to 15%. Also I need to idle up and then have engine cut off. I can't seem to follow my manuel to do this. Thanks for giving us this forum.
Tom
Tom
RE: 8103 throttle up-down
To do this in each case set up a program mix, mixing throttle to throttle, assign the mix to a switch (likely 2 switches will be used for both functions, and 2 program mixes), and set the rates as needed to reduce the throttle. In each case, it should require negative percentages in the mixes.
