XP8103 'stick monitor' issue
WA
When monitoring the stick travel indicators on the LCD display, I've noticed that moving either the aileron or rudder stick left will result in the indicator moving right, and vise versa. This happens with the servo direction in the normal positions (i.e. not reversed). Every 8103 transmitter seems to behave this way (I've checked four so far, and all were heli radios). Is this a known issue? Am I interpreting the monitor function incorrectly? Thanks!
RE: XP8103 'stick monitor' issue
The monitor shows movement yes, but it's intention is not to verify direction of movement. Correct direction of movement is determined in the model.
