8103 mixing problem
8103 mixing problem
Hi Danny,
I am using an 8103(A) airplane radio set for use with a Heli. I need to know how to mix some switches. Currently I am using the invert switch as my on/off switch for my gv-1 governor and the throttle hold switch for its intended purpose. However when the gv-1 is operating normally and I hit my throttle hold, the governor does not disingage and I still have power to the engine. I was wondering if you have a solution to this using the programmable mixing or other solution?
Josh
Josh
RE: 8103 mixing problem
It sounds like you will need to use a program mix, perhaps a mix where you mix the channel that the governor is plugged into to itself, assign the mix to the gear/invert switch, and set the rates as need to disable the governor.
Hello Danny,
What I need from you is to actually give me the steps for programming this scenerio. I'm sorry if I wasn't clear in my earlier post.
I don't have a govenor and have never used one so I can't give exact directions. Mix the channel to itself, assign it to the switch of your choice, and set the rates. If the mix doesn't work, you may need to add an offset in the mix. The manual describes how to set up program mixes. It is available online if you don't have a copy.
