JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
JR 9303 - Rudder/Spoiler set up
Old 10-14-2004, 08:48 AM
rgteel
Default JR 9303 - Rudder/Spoiler set up
Hello Danny,
I have a basic 3 channel sailplane (Rudder, Elevator and Spoiler) and I was planning
to use my JR 9303 with a Hitec 555 receiver.
In the Sailplane mode, the programming seems to set up for using 2 servos to operate
the ailerons. I plug the spoiler servo in the #1 position in the receiver and the spoiler
moves with the rudder. This is same set up that I had using with my JR8103.
If I use a 7 channel receiver, I can get it to work properly when using an AUX channel.
I just don't want to use the 7 channel receiver in a 3 channel model.
I want to thank you for all of the info that you have been providing for the JR products.
I have been a very satisfied JR user for many years and have owned most of the JR transmitters.
Keep up the good work.
Randy
Old 10-20-2004, 09:04 AM
dsnyder
dsnyder's Avatar
Default RE: JR 9303 - Rudder/Spoiler set up
How are you wanting the spoilers set up? If it is just moving with the throttle stick, set up the MOTO function in device select on SPOI STK and activate it, and use channel 5 for your spoilers. This is the easiest solution I can see, if it will work for your model.
Old 10-22-2004, 11:39 AM
rgteel
Danny,
Thanks for the information. It is now working as desired.
Randy
