JR X2610 Tx mixing
JR X2610 Tx mixing
Can anyone out there help with the following mixing setup on the JR X2610 Transmitter:
Right hand toggle switch to lower flaps to, say 15 degrees, then followed by left hand toggle switch to lower flaps from the previosly set 15 degrees to say 30 degrees. In other words I would like to use the two toggle switches to progressively lower flaps in stages.
I can't fathom the master/slave configuration and offsets?
thanks in advance
Ron
thanks in advance
Ron
RE: JR X2610 Tx mixing
The easiest way is to set the flap switch in the switch select function to one of the two switches and the gear to the other. Then use the flap system to set the flap switch, then set up a gear to flap mix, move the gear switch in the position you want more throw and enter the percentage desired. You can also use sub trim on the flap channel to get more throw on the flaps if necessary.
