JR 10X
My Feedback: (12)
JR 10X
I have a JR10X and when I first turn on the receiver all the servos jump and then return to the commanded positions. This is a problem because my sequencing gear doors will open and close out of sequence with the retracts. What can be done to prevent this ?
RE: JR 10X
There isn't anything that can be done on the radio end, the jumping you are seeing is happening during initilization of the receiver while it sets itself during power up. The only thing you can do is set the model so that the jumping doesn't affect anything.
My Feedback: (12)
RE: JR 10X
The problem was that the Jomar door sequencer switch #3 had to be in the proper position in relation to the retract sw on the TX. I did not have the TX and sequencer properly setup. RTFI !!!
