6102 Airplane throttle curve mixing
My Feedback: (32)
Hi Danny,
I have a 6102 with all 6 channels in use for a Funtana 90 (using mix 4 for elevator with the gear channel and the gear switch inhibited). 2 aileron servos on seperate channels and the normal rudder and throttle channels.
I want to start playing with throttle curve mixing and I know that I can set one of the other mixes to throttle-throttle but as far as what to do with the offset and percentages is what is eluding me.
The manual does not explain it in any detail and searches for creating the mix all lead to the helicopter function. The problem with setting it up in heli mode is that it appears I cannot mix elevator to gear and get the trim to function correctly, or is it possible and I am just confused.
What would be the best solution for this as you see it and can you explain it in a little more detail please?
Also, where can I get JR stickers for on my flight box and airplanes?
RE: 6102 Airplane throttle curve mixing
The 6102 for aircraft does not have a throttle curve function, and since it does not have any multi-point program mixes, there isn't a way to set one up. Using a program mix will only alter your overall travel which does not serve the purpose of a throttle curve. So I'm sorry to say that this isn't possible with the 6102.
For decals, we carry these:
JRPA950 JR AIRCRAFT DECALS
JRPA955 MEDIUM JR AERO DECAL SHEET
JRPA960 LARGE JR AERO DECAL SHEET
JRPA970B 4" JR VINYL DECAL: BLACK (2)
JRPA970R 4" JR VINYL DECAL: RED (2)
JRPA970W 4" JR VINYL DECAL: WHITE (2)
JRPA972B 6" JR VINYL DECAL: BLACK (2)
JRPA972R 6" JR VINYL DECAL: RED (2)
JRPA972W 6" JR VINYL DECAL: WHITE (2)
JRPA974B 9" JR VINYL DECAL: BLACK (2)
JRPA974R 9" JR VINYL DECAL: RED (2)
JRPA974W 9" JR VINYL DECAL: WHITE (2)
JRPA976B 12" JR VINYL DECAL: BLACK (2)
JRPA976R 12" JR VINYL DECAL: RED (2)
JRPA976W 12" JR VINYL DECAL: WHITE (2)
JRPA978B 18" JR VINYL DECAL: BLACK (2)
JRPA978R 18" JR VINYL DECAL: RED (2)
JRPA978W 18" JR VINYL DECAL: WHITE (2)
JRPA980B 24" JR VINYL DECAL: BLACK (2)
JRPA980R 24" JR VINYL DECAL: RED (2)
JRPA980W 24" JR VINYL DECAL: WHITE (2)
JRPA982B 36"JR VINYL DECAL:BLACK (2)
JRPA982R 36"JR VINYL DECAL: RED (2)
JRPA982W 36"JR VINYL DECAL: WHITE (2)
JRPA984B 48"JR VINYL DECAL: BLACK (2)
JRPA984R 48"JR VINYL DECAL: RED (2)
JRPA984W 48"JR VINYL DECAL: WHITE (2)
If you wanted custom graphics, I personnally use Die-Hard Graphics, www.die-hardgraphics.com
My Feedback: (32)
Dave,
Thanks for the info on the throttle, it's no big deal and nothing that I can't live with, yet.
Guess it's soon time to look into the 9303.
I gather then I have to order the stock decals. I actually have used Die-Hard Graphics in the past, they do nice work.
You can make some mechanical adjustments to the throttle set up to help if the problem is severe, either by changing the distance out on the servo or the horn on the throttle, and then make travel adjust changes if necessary.
To get those decals, yes you would have to order them.
