JR 6102: in-flight flap trim possible?
Hi,
I recently got a JR 6102 radio. So far the radio is simple but powerful, perfect for my needs.
It is not clear from the manual, but is it possible to set up one of the levers (the buttons with +/-) to trim the flaps during a flight? For example, I want to have one switch to activate the flaps and then use the rocker to adjust the amount flap needed.
RE: JR 6102: in-flight flap trim possible?
The Flap/Hover Pitch lever is pre-set to be the flap trim function. If you select a switch to control the flaps in the switch select function, the flap lever is pre-activated.
