JR 10 SX II Switch Assignment
TN
Danny,
With a 10SXII can you actually assign functions to different switches or multiple functions to any switch or can you just disable certain switches from being used or only with program mixes ? I read through the manual and could not really tell. Is this the same way a JR 10 X functions ? Speaking of a 10X, besides the digital trims, no meter, no programmable failsafe, what are the differences in the programming from a 10SX II ?
I am trying to compare what I have read about the 9303. It appears to have total switch assignment flexibility, even more so than the 10X.
Thanks.
Thanks.
RE: JR 10 SX II Switch Assignment
You can use program mixing to set just about every switch to a given function. There are a few limitations, but not many. Yes, the 10X works similarly in this respect. The 10SXII has programmable failsafe just the same as the 10X. The flight mode functions were improved in the 10X, as well as a re-designed case, and a few other programming improvements. The 9303 is a bit more flexible/easy to assign switches to functions etc.
