8103 program flaperon on rec chan 5
Hi, I have a foamie airplane with a 5 channel receiver. I have two airlion servos that I would like to use as flaperons but the 8103 uses channel 6 instead of channel 5.
Is their away to program the radio to do this? Perhaps through mixing.
Thank You,
Mark
Thank You,
Mark
RE: 8103 program flaperon on rec chan 5
Yes, you could use mix 5 or 6, mix aileron to gear, and set the rates to 100% in both directions of aileron. Then in mix 3 or 4, set up a gear to gear mix, and set the rates to -100% in both gear switch positions.
