Transmitter Module
FL
Transmitter Module
Is the module tuned to the channel crystal? If not and you can change module's on a 8103 from one frequency to another! Doesn't changing the crystal in the module do the same thing!
RE: Transmitter Module
It is against FCC regulations to change the frequency of a transmitter (module) excpet when performed by an authorized service center. You can change the modules from one system to another, but you can not change the frequency of a module or transmitter per the FCC.
