8103 throttle curve setup for 3d
RE: 8103 throttle curve setup for 3d
To set up a throttle curve, set up a throttle to throttle mix in mix 1 or 2, set points L and H to 0 percent (so that the mix doesn't affect your travel adjust) and use small percentages in points 1,2, and 3 to set the curve as needed. You'll only want to use small percentages to alter the curve as needed. Positive percentages will speed the response, and negative percentages will slow the response. If the percentage used is too high it can possibly cause the throttle to increase, then decrease, then increase again. The percentage must be low enough to not cause the mix to overcome the throttle travel, but large enough to alter the curve as desired.
