JR nes 8300 servo?
JR nes 8300 servo?
Hi,
Has someone a sollution to fit the JR servos NES8300 onto a Futaba R 149DP receiver?
I have got a problem soon i switch on the receiver, these servo travel to their end possition and return than to the middle point. Ihave used some different types of Futaba PCM receivers all the same problem. When I tried with the PPM receiver there is no problem
Hope to get some help tanks.
Ed
Ed
JR nes 8300 servo?
It should work fine. I assume that the PCM receivers are working with other servos. If not, you may just need to change the modulation of the TX. If this is not the case, it is difficult to say what the problem is, and it may just be a compatablity problem between the 2 brands.
