6102 for Eco 8 help
My Feedback: (17)
NJ
6102 for Eco 8 help
Hi Danny
I have a new 6102 but I am having trouble getting it setup in my Eco 8.
I have the 120 swash but I can't get the servos to all do as they should.
Could you review what my servo connections s/b to the reciever and the settings in the radio menu.
Steve
Steve
RE: 6102 for Eco 8 help
I do not know the settings needed for that heli. There is a pretty good amount of information on setting up the CCPM beginning on page 66 of the manual including channel assignments. What problems are you having setting these?
My Feedback: (17)
NJ
I set the servos with elv in elv slot, right air servo in ch 6(aux 1) and left servo in ch 2.
I choose the swash 3 servo 120. I get the elevator to work ok and the aileron to work ok but when I push up the throttle the servo arms on both the aileron servos go down instead of up for increase pitch.
What are your current CCPM and reverse settings? So far I'm not finding a way to electronically correct that, it seems that you may need to rotate 1 servo arm 180 degrees because it seems to be out of phase, but with the CCPM settings I can check further.
