9303 flight modes & D/R
OK
Danny,
When setting up the 9303 for flight modes to have three D/R, how do you set up the D/R for each mode?
I have flight modes set up on the flap 3 position switch. Do I change position on the flap switch to set up the different D/R?
I would also like to have different trims for each mode, this is accomplished by the the com-fm?
My Feedback: (54)
RE: 9303 flight modes & D/R
Once you set up flight modes, if you go into the D/R and Expo screen from the Function List, you will be shown three sets of rates for each control surface. Just highlight and select the control surface, then set the rates for each flight mode. The Trim: Com or FM will get you where you want with the trims.
