652 Flaperons R700
652 Flaperons R700
I have read through the posts on flaperons but I am still confused on my issue. I am using the 652 tx with the R700 rx.
I am trying to set up flaperons on my 4*60. I am not doing this for landing/takeoffs but simply to have more fun with tight loops, etc. Everything is working right- flaps are mixed with elevator so they go down when elevator goes up and vice versa.
However, when I throw the switch to turn the flaps on, they go down (as flaps). Can I set this so when I flip the switch the flaps do not move until I input up or down elevator?
Thank you,
Steven
Thank you,
Steven
RE: 652 Flaperons R700
You can set the travel adjust on the flap channel to 0 in both switch positions, and then the ailerons would only move as flaps when the mix is active.
