8103 throttle mixing multi engine
My Feedback: (8)
FL
I am using the rudder channel to mix my second motor due to the electric plane I have is twin motor no rudder. I have the channel mixed but the problem is I can't get the motor on the rudder channel to go full throttle unless I input left rudder.
RE: 8103 throttle mixing multi engine
The best way I can think of at the moment to overcome that would be to set the throttle and rudder channel travel adjustments both to 150%. If I think of any other work around for that I'll let you know.
My Feedback: (8)
FL
I tried that, no joy. I'm using a small 4-channel receiver and I don't think I can trick the rudder channel into mixing completely. I tried the sub trim and bumped up the throttle and rudder to 150%. I think my only options are going to be a "Y" splitter or a 5-channel receiver.
