9303 Elevator mixing
My Feedback: (32)
Hi Danny,
On a 9303 which of the 6 mixes allows trim to work for both the master and slave channels
On my 6102 I could use mix #4, inhibit the gear switch and mix elevator to gear so that when I would use trim both channels would move. On the 6102 mix #4 was the only one that allowed this
RE: 9303 Elevator mixing
In aircraft mode, none of them do. But it does have the dual elevator, dual aileron, dual flap, dual rudder, and dual throttle functions in the wing type menu, which allows you to simply activate this function. Just inhibit the channel you wish to use in device select prior to going in to the wing type menu.
My Feedback: (32)
I appreciate the response. I sat down with the radio on my lap and re-read the manual and it hit me on how to do this. No mixes needed just do what you said and off she goes...cool stuff.
I must say, once you earn all the little tricks with this radio it's really not to hard to setup.
BTW...I am using flight modes. I like the idea of having 3 seperate D/R's to setup
