Mixixng question for 10SX
TX
Danny, I have a PCM10SX and I have recently built a Tensor but I added a second aileron servo. I have them mixed and working with out any problem, but I can't figure out how to disable the the switch assigned to the slave channel. I can't see anything in the manual that addresses this. I am afraid that I (or someone else) will bump the switch while I am flying and the ailerons on one side will drop if that happens! I don't know if it matters, but I also have added bi-directional flaps (aileron/flap mixing) assigned to the auto/brake switch to turn that one mix off and on. I have a 6 channel rx and have tried using channels 5 and 6 both having the same problem with their respective switch. Hope I have explained the problem clearly, and thanks in advance for your help.
Mark
Mark
TX
RE: Mixixng question for 10SX
Danny, thanks for your speedy reply, and that is how I initially set it up. The only problem with that is my whole purpose for adding the second servo was to have the bi-directional stunt flaps, if I inhibit the flaps, that feature won't work. I just need to disable the switch. I know any programming question is a tough question when the radio is out of production, but hopefully there is somebody out there reading this who is still using a 10SX, and has had to do this. I have talked to many people and their standard answer is "I'm sure you can do it, but I don't know how." Well that is what I think too!
Thanks again Danny,
Mark
Thanks again Danny,
Mark
Most of the time for 3D type models, you mix elevator to flap assigned to a switch to use either spoilers or flaps. Inhibiting the flaps in code 17 just inhibits the slider on the left hand side from affecting your ailerons.
