Differential ailerons and flaps
ID
Danny,
Can you set up the 9303 to allow for differential ailerons and a flap function? Or is the aileron differential feature only available in installations without flaps?
Randy
Randy
ID
RE: Differential ailerons and flaps
So differential ailerons are not available with flaps. For differential ailerons you must use the Flaperon wing type and for the flaps to operate as a seperate system you must use the Normal wing type. Correct?
Randy
Randy
ID
OK I'll give it a go. In the normal wing mode I'll slave an aux channel to the aileron channel and things should be good. Do I just adjust the end-points to achieve differential throw?
Randy
Randy
Simply activate dual aileron in wing type after inhibiting the aux channel in device select, then use the differential function in the function list.
