9303 camber & reflex set up
NY
New to a 9303 & getting frustrated trying to set up camber & reflex on my dlg, which uses flaperons. Also please help me on switch assignment. Want to be able to adj camber & reflex on left side slider.
Thanx
Greg
Thanx
Greg
RE: 9303 camber & reflex set up
If you have a value set in the Flap Rate function, you can simply enter the desired rates in the Flaperon Mix function (also called Camber Mix function in some systems). If you do not have anything set up in the flap rate function, you can set up a program mix to do this. Set up a #FLP -> FPRN, and set the rates as needed. In device select, the flap lever will need to be assigned to the Flaps in order for this mix to use the left slider.
NY
Danny
Thanx- Feeling kind of stupid-all wriiten & right in front of me. That's what happens when spend too long on one thing, & up too late.
Thanx again
Greg
PS: Great radio !!!
Thanx again
Greg
PS: Great radio !!!
