JR 9X change MODE 1 to MODE 2 ?
Hello.
I have JR 9X (9303 in the USA) which works in MODE 1 and does not allow to change MODE in SYSTEM MENU.
How can I change MODE 1 on MODE 2 ???
RE: JR 9X change MODE 1 to MODE 2 ?
In Moscow there is no agent of service JR.
How I can change MODE independently?
Reading a forum, I met answers on other models JR where it was spoken about rearrangement jumpers or the engineering menu.
What situation with JR 9X?
Excuse me for my English.
CA
To my surprise i have to 9X with me . One supports with the software mode changing feature and the other one does not. I think the JR company has no set standards.....[>:]
The PCM9X is NOT the 9303 ! The 9303 is a development on the 9X, and the 9XII is a variant of the 9303.
JR does have set standards depending where the transmitter was sourced from. The NET code indicates quite clearly what can and cant be done. If it is a ES variant, then mode change is allowed, if it is an HS or FS this implies that it is fixed for either Heli or Fixed Wing and as such will invariably be fixed mode.
The original 9X was set to ES for export and FS & HS where for the home markets.
Alexx, whereabouts did you buy the 9X from ? They should be able to advise where to send it to get the mode change implemented. Question for you, is it all 4 digital trims or is it a 1 +3 ?
[8D]
[8D]
