Removing Battery Connector in Transmitter.
FL
Danny,
I am changing the main battery in my JR 652 & 421EX Transmitters. I can not get the battery plugs to release
from the mainboard receptacle. There must be a sequence to be followed that I am not aware of! Any advice?
RE: Removing Battery Connector in Transmitter.
I assume they are the black connector type. They can be tricky, don't be tempted to use too much force as you can break the connector in the transmitter fairly easily. I generally use a thin flat blade screw driver or finger nail to gently lift up on the housing on top of the plug, and then pull on the connector. When it releases properly it will not take very much force to pull the connector out of the housing.
