flaperons w/ 6102
WI
flaperons w/ 6102
Hello-
I'm wondering if there's a way to set up my radio system for flaperons.
Tx- 6102
Rx- Hitec 555
plane- sailplane; V-Tail, Flaperons.
I would like to be able to digitally control trim, sub-trim etc. on all functions.
thank you for your help-
Michael
Tx- 6102
Rx- Hitec 555
Michael
RE: flaperons w/ 6102
You need a 6 channel receiver to use the flaperon function. You could mix aileron to gear in mix 4 and set the rates at 100% to use 2 channels for the ailerons.
WI
I've added a JR 8103 to my equipment, and I'm looking to progam a 4 servo DLG. With the additional options in the 8103 will I be able to program flaperons with a 5 channel receiver?
The 8103 is the same w/ regards to the flaperon function, it uses channel 6. However, just as in the case with the 6102, you can program dual aileron etc with program mixing.
