JR 9303 and 4 alierons
WI
I am going to be getting a big biplane and i wanted to know if the 9303 can slave 4 servos for the alierons or will i need to get 2 Y harnesses?
By the way I love this Radio
My Feedback: (48)
CT
RE: JR 9303 and 4 alierons
could you set up the radio with dual aielerons for the bottom wing. and then use a mix to slave the other two ailerons to the lower channels??? That is how I did it on my 9c and will eliminate the need for y's or matchboxes and give you precise controll over each surface??
CA
I tried it and found that the mix four servo lagged behind the main channel? not sure why or who to call so I used a Y which is not what I wanted to do since I had 4 alierons on my edge 540
