6102 throttle expo
6102 throttle expo
Hello,
I was wondering if the JR6102 can do expo on throttle? and if it can do expo for rudder,aileron, and elevator(mostly for 3D stuff)
also can you do the expo for these independently or if they have to be mix together or can you do both. One last question, can you assign switches to do what you want or are they unassignable.
Thanks so Much!
Jay
Thanks so Much!
Jay
RE: 6102 throttle expo
Expo is not available for the throttle. Expo is available for the elevator and aileron, and rudder as well if you use the combined switch function (essentially this would be similar to flight modes). The expo is set for each function idependantly. You can assign the switches to various functions.
