Ultra Stick Programming 9303
I found the manual for programming a H-9 Ultra Stick on the 9303. I don't want to sound stupid here but I could'nt get everything to work. I just got the radio after moving up from a 8103, so I'm not real familiar with it yet.
I guess my question is will there be a new complete write up for putting in future manuals for the Ultra Stick?? The directions in past manuals were very detailed and more set by step. I got thru setting up 2 Ultra Sticks with a 652 and the 8103, but I can't make it thru getting the ailerons and the flaps coupled with the 9303.
Any chance of more comprehensive detailed instructions like the building manuals ?? One for dummys so to speak
Help Danny.!!!!!!....What I would like to use is the gear switch to couple the ailerons to the flaps for a solid surface when I want some serious roll control.
I got the Flap switch working with 2 step's postions, And I don't see needing the crow set. Never really used it on the others.. But Ail-Flaps coupling Ya.. I need that.
Thanks Danny for any help.
RE: Ultra Stick Programming 9303
The instructions on the web site take you through the necessary programming step by step. There really isn't much of anything to add. You'll set the flaps up as ailerons with the aileron to FROL mix, if you would like this on the gear switch rather than the mix switch, select the gear switch in the mix rather than the MIX switch as stated. This mix is described in the Aileron to Flap mixing section of the guide. The crow is a nice feature to fly extremely slow, and do things like a very slow dive into a short landing. That is set up in the flap to FPRN mix, which is the last mix described in the guide on the web site.
