JR 8103 and what receivers ?
My Feedback: (16)
TX
I tried to use yesterday a R700 and R600 receiver with my JR 8103 TX and found out that this didn't work. Can I only use R549 & S-PCM R649 with this radio ? Also, what 8 channel Hitec receiver will work with the 8103 ?
All of those JR receivers will work with the 8103. You will need to change the modulation in the 8103 to match the receiver you are using. The modulation will be PPM for the R700, R600, and R549 and SPCM for the R649. Also be sure the crystals match frequency and you have a crystal with a black case in the 8103 and a crystal in a gray case in those receivers.
Hitec makes an 8 channel supreme receiver that will work with JR. If you do look for a hitec receiver, be sure that it has on the label that it is for JR. Otherwise it is probably negative shift which is incompatible with JR's positive shift.
